Re: Ches. 17. How much Ep
Posted by Jim E on Sep 24, 2007
I would not worry too much about having insufficient epoxy. Just keep an eye on it, and you will know ahead of time that you are going to run out. Then you can order another small pack if necessary. You should be doing fill coats by then, so there's little risk of messing up a glassing session.
In Response to: Re: Ches. 17. How much Ep by Kyle Lindstrom on Sep 24, 2007
- Re: Ches. 17. How much Ep by Doug W. on Sep 27, 2007
