Re: Hull Curvature
Posted by Jim E on Apr 3, 2007
Hopefully you're still at the panel stitching stage, so this can be fixed. If one side curves more than the other, then the ends will overlap slightly, with the less curved panel seeming slightly longer than the other. You might be able to fix it by loosening the ends, then pulling the sides into the correct relationship, while tightening the ends again. Hopefully the keel line is straight.
In Response to: Hull Curvature by Doug on Apr 3, 2007
