Re: Frayed ends?
Posted by Mike on Mar 13, 2007
I had the best luck wetting the cloth down with epoxy, then lifting it up and cutting it. Then you just sort of push it back down. I discovered it is no big deal either way. It all gets covered up with epoxy and sanded out in the end anyway. But obviously, the neater you are now, the less work later.
In Response to: Frayed ends? by Jon B. on Mar 13, 2007
- Re: Frayed ends? by Garland on Mar 13, 2007
Re: Frayed ends? by Tom S on Mar 14, 2007
- Re: Frayed ends? by Garland Gray on Mar 15, 2007
