Scarf Joint Look
Posted by Stan Hochberg on Sep 10, 2006
Does anyone have any tips for improving the look of scarf joints after glued and sanded, before fiberglassed. Mine are a bit wide, irregular and have black lines at the edge (? from too much sanding). I was wondering if anyone patched them with wood epoxy or something else or had a way to put a thin veneer back over them. The joint is structurally fine.
