Re: Deck Rigging Screw Ho
Posted by Rod Tait on Nov 23, 2005
I usually recommend that the holes be drilled about 50% larger than the hole required. Or you can drill close to the size and then use a Q-tip to get some epoxy in there and seal the edges. I would not rely on silicone alone. If water does manage to get in there, your wood will discolour and you will not be able to get rid of the stain.
In Response to: Deck Rigging Screw Holes by Chuck on Nov 23, 2005
