Wet Sanding Varnish
Posted by Chuck on Nov 10, 2005
Just put on my first coat of varnish on the deck of my C-17. Looks fantastic! Now am ready to wet sand in prep for second coat. Should I do all wet sanding with 400 grit or start with a heavier grit first and then finish with 400? Is there any need for anything finer than 400 for the last couple coats? I plan to do five coats of Z-Spar Captains Varnish.
Thanks for the tips.
Chuck
- Re: Wet Sanding Varnish by George K on Nov 10, 2005
Re: Wet Sanding Varnish by Steve Miller on Nov 10, 2005
- Re: Wet Sanding Varnish by Chuck on Nov 10, 2005
- Re: Wet Sanding Varnish by Moe on Nov 11, 2005
