Re: Wet Sanding Varnish
Posted by Chuck on Nov 10, 2005
George, Steve:
Thanks for the wetsanding tips and I plan to get that 400 grit out tomorrow, with lots of water, and get her ready for the next coat. I never thought of using the 3M Pad every other coat but will give that a try after the second coat. Since I am painting the hull with one part PolyU I have to finish wet sanding the primer coat too. I will post some photos when I finish.
Chesapeake, VA
In Response to: Re: Wet Sanding Varnish by Steve Miller on Nov 10, 2005
