Re: fillets
Posted by LeeG on Oct 10, 2005
I first built a Patuxent 17 and made the fillets as large as the drawings,,which put at least two quarts of expensive dookie schmootz in the kayak. After that built a GoldenEye13 where the wires are pulled after unthickened epoxy is used to hold things together. Thereafter I did the same with four panel hulls. Use a syringe to apply slightly thickened epoxy along the inside then pull the wires when everthing is cured.
In Response to: Re: fillets by paul on Oct 10, 2005
