Re: cutting wires
Posted by david on Aug 19, 2005
Make yourself a pair of nippers. Use a file to turn the normal "V" shaped cutter blade into a half-V shape. Looking at the nippers head on, one side will be vertical, the other at the original angle. Wire cuts will be flat with no little ridge to draw blood.
In Response to: Re: cutting wires by RogerJ on Aug 19, 2005
