Re: cutting wires
Posted by RogerJ on Aug 19, 2005
If you haven't buried them in epoxy pull them. Make "tabs" of thickened epoxy between the wires, when they have cured you can pull the wires. Put tape over the out side of the hull, over the holes to cut down on drips, and run your inside fillets right over the holes. That will fill most of them. Once the fillets are done you can fill the remaining dimples from the out side, you're going to tape over the chines too, right. RogerJ
In Response to: Re: cutting wires by John on Aug 19, 2005
