Re: spring back of flush
Posted by patrick forrester on May 25, 2005
I wonder if I go forward and then have a problem if I could add more curve to the 8mm hatch forceing them down to a set of ribs like you do with the normal 4mm hatch covers.
Anyway I am sure there will be some (may be near zero ) bounce back. And if my jig matches the radious of my deck, putting the hatch on top of the jig will result in a larger radious ( it will be minor ) becuase it is on the outside of the jig thus making a bigger radious.
Anyway I am going to do a little bit of sanding on the jigs to reduce their radious to less than my deck radious. I am only going to do it a litte bit though.
If I hear a reply from somebody with experience in this I may change my plan.
I really hope to hear from somebody soon. I need to finish my boat for a trip.
http://www.virtualboss.net
In Response to: Re: spring back of flush by LeeG on May 25, 2005
- Re: spring back of flush by FrankP on May 26, 2005
