Re: ANSWER..I just did th
Posted by Dick R on May 23, 2005
It really is not necessary to remove the stitching wires. I simply used fingernail clippers to cut real close, then light sanding. (I could get a closer clip than using wire nippers.) If you really want to remove the wires, the soldering iron method mentioned above to soften the epoxy will work fine --- but why bother?
In Response to: Re: ANSWER..I just did th by Mike D on May 23, 2005
- Re: ANSWER..I just did th by mullman on May 23, 2005
- Re: ANSWER..I just did th by Pete on May 24, 2005
- Re: ANSWER..I just did th by Laszlo on May 24, 2005
