Re: ANSWER..I just did th
Posted by Mike D on May 23, 2005
I had a similar experience with removing wires from the WR18 I am slowly, very slowly, building.
Instead of a small pencil shaped soldering iron ( I gave up after looking for it for an hour)I used one of the pistol type soldering guns. More watts so the wires heated after only 5 to 10 seconds. It is amazing so well the heat softens even fully cured epoxy and the wires pull right out.
I agree that blow torches are not a real good idea, but the soldering gun is really easy.
Happy buildiing, MD
In Response to: ANSWER..I just did this by mullman on May 23, 2005
- Re: ANSWER..I just did th by Dick R on May 23, 2005
Re: ANSWER..I just did th by mullman on May 23, 2005
- Re: ANSWER..I just did th by Pete on May 24, 2005
- Re: ANSWER..I just did th by Laszlo on May 24, 2005
