Re: Footbrace mounting st
Posted by CLC on Apr 19, 2005
>>>>>>>>>>>>>>>>> Can someone tell me how big the base is on the actual CLC mounting studs and what size bolt/thread the CLC studs use?
The threads on the studs are 1/4-20. The base of the mounting stud measures about 1.25" x 1.25".
You have to 'glass it in place. Footbrace mounts can experience very high loading, so keep that in mind if you switch from the KISS-principle through-hull bolt system.
Our footbrace mounting kit includes four mounting studs, nylon locking nuts, washers, fiberglass, and two pages of instructions specific to mounting them inside S&G kayaks.
CLC Footbrace Mounting Kit
In Response to: Re: Footbrace mounting st by Brett on Apr 19, 2005
