Re: Wavy Fillet
Posted by Brett on Apr 7, 2005
I made the same mistake - followed the manual and layed the glass straight onto wet fillets which came out a little wavy. After you get the epoxy coats on there it doesn't look bad at all and in the cockpit you will hardly see it at all beceause the deck or the seat covers the view of most of the seams. If that is the worst mistake you make on the boat you wont have much to worry about.
In Response to: Re: Wavy Fillet by CLC on Apr 7, 2005
