Perfectly done, Lloyd
Posted by Robert N Pruden on Dec 4, 2004
Setting the stitches loose at first then tightening them is exactly the way to get perfect stitches on a straight boat. Nicely done! The lines look great. You're using about double the wire you could be using. I found that using the pliers that electricians use to twist wires (flat headed things) works to create nice twists.
Robert N Pruden
In Response to: Stitch in Time by Lloyd on Dec 3, 2004
Fall Kit Sale 2016
