Re: Getting closer...
Posted by Chris Taylor on Oct 21, 2004
There is no question the next one will be "better" (lighter, neater) but this is often not readily apparent to most observers). The first will always have a special beauty to you due to the emmense pride it will give you.
To avoid the wetting-out problem you had when you do the deck and on future projects, mix many small batches of epoxy rather than fewer larger batches (only enough for 10 or 15 min of work at a time). It seems tedious, but as soon as the epoxy starts to kick even a little, its a problem to spread. I know... this is why my first is painted too (which as I mentioned, worked out just fine - as do most of the problems we encounter).
In Response to: Re: Getting closer... by jahrome on Oct 21, 2004
