Re: shortning the beam
Posted by Doug Rhude on Oct 4, 2004
WOW! Alot of responses, Ety Bahar, I've built a 17lt kit & have narrowed my beam to 22", every thing built as spec'd normally. The only thing that changed as far as the hull goes is you decrease the amount of rocker the hull has, making her track a little better. I moved the bulkhead(front) aft a few inches,witch(sp) I wanted to do anyways. It's not that radical of a change. Now, to modify the width of panels, That's another story! Enter that realm at your own risk! Doug Rhude
In Response to: Re: shortning the beam by J.Schott on Oct 4, 2004
Fall Kit Sale 2016
