Re: 5 minute epoxie
Posted by RogerJ on Sep 16, 2004
I agree, the brand I used (Wet Systems ) states thier rapid cure epoxy ( G-5 ? ) is not for marine use. In a warm environment epoxy will harden pretty quick. At 85 df I have been able to apply and at least scrape the same day. I guess it depends what the temp's are where you are working, maybe a little help from a lamp with an incandescent bulb to warm locally. RogerJ
In Response to: Re: 5 minute epoxie by Howard on Sep 16, 2004
