Re: 5 minute epoxie
Posted by Howard on Sep 16, 2004
i would highly recommnend you DO NOT use 5 minute epoxy.
most brands i am aware of are not designed for marine use and will disolve/degrade when exposed to water.
i would take your time and continue to work with the epoxy you are building the rest of the boat with ...which if it is MAS...should be MAS.
In Response to: 5 minute epoxie by Peter on Sep 16, 2004
- Re: 5 minute epoxie by RogerJ on Sep 16, 2004
