Re: zsilvertip epoxy
Posted by LeeG on Aug 31, 2004
Actually CLC shop space is ideal,,constant temperature and not as humid as some garage spaces in the middle of green lawns, so they may not have the chance to experience extremes that the home builder works under. Your experience posted below is different than System3 and CLCs product description.
"Application: Use at a simple 2:1 volume ratio with either the fast or slow hardener. Use at temperatures as low as 35F with no limitations on humidity. Even at lower temperatures and higher humidity this resin will not blush on curing. The medium-low viscosity of SilverTip Laminating Resin wets out fiberglass cloth quickly and allows for use "as is" for coating either coating or fiberglass work."
In Response to: Re: zsilvertip epoxy by DaveW on Aug 31, 2004
