Re: zsilvertip epoxy
Posted by DaveW on Aug 31, 2004
The wetout is excellent. Not too much difference in viscosity. The Silvertip sets up faster. I've only used the slow hardener, so can't answer your question on the fast, but CLC has probably done enough work with it that they could tell you.
In Response to: zsilvertip epoxy by Greg Root on Aug 31, 2004
- Re: zsilvertip epoxy by LeeG on Aug 31, 2004
Yes, should add . . . by DaveW on Aug 31, 2004
- Re: Yes, should add . . . by Terry Mcadams on Sep 1, 2004
- Re: Yes, should add . . . by DaveW on Sep 1, 2004
- Re: Yes, should add . . . by Laszlo on Sep 1, 2004
- Nice tip - thanks! by DaveW on Sep 1, 2004
- Re: Nice tip - thanks! by Laszlo on Sep 2, 2004
