Re: Resin over varnish
Posted by Don on Jul 19, 2004
Use Interlux 202 solvent to remove the varnish. It does a really good job and is pretty easy to do. Then you can apply another coat of epoxy without wondering if it will addhere properly. I would sand the epoxy before applying another coat.
In Response to: Resin over varnish by Jim Skovron on Jul 19, 2004
Fall Kit Sale 2016
