Re: Resin over varnish
Posted by Steve Miller on Jul 19, 2004
Curious as to how you sanded into the cloth trying to get a bad coat of varnish off. Wet sanding with 400 should be all it takes to smooth out varnish. Go easy on the grits. The paint and varnish companies all seem to tell you to sand with paper that is way too coarse between coats.
By the time you have a good 4 to 6 coats on you will be doing much better. Good luck.
In Response to: Re: Resin over varnish by Don on Jul 19, 2004
