drills and paints
Posted by Chris F on Jun 7, 2004
Ok, I'm a novice and the "#8 Fuller bit set to 1 1/2" for countersink" reads a little rought to me. I analyzed this online and I think I know what I need, but I'm sure not buying the $70 bit set for two holes.... Any advice.
Next question. My epoxy job on the cockpit leaves much to be desired. I worked out all the kinks and the hull looks great. In order to mask my cockpit shortcomings I'm going to paint it white. Would you recommend primer? How many coats?
Thanks for the input.
- Re: drills and paints by Doug Judd on Jun 7, 2004
- Re: drills and paints by Bill Cooke on Jun 7, 2004
- Re: drills and paints by Mac on Jun 7, 2004
- Re: drills and paints by Terry Mcadams on Jun 7, 2004
- Re: drills and paints by Chris F on Jun 7, 2004
- Re: drills and paints by Steve Miller on Jun 7, 2004
