Re: drills and paints
Posted by Bill Cooke on Jun 7, 2004
Chris - The suggestions you have reseived are fine - The only suggestion I make is to drill a hole the size of the screw head (or slightly larger) about an 1/8 pf ionch or so deep and then epoxy in a piece of dowel the size of the drill bit - leaving it a bit proud (extended) when cured you can bring it down even with the wood and will produce a nice "plug" look
Bill
In Response to: Re: drills and paints by Doug Judd on Jun 7, 2004
