Re: epoxy concerns
Posted by Ron Paro on Mar 1, 2008
larry asked: "could somebody give a weight to use for clamping,1,2,3.4,5,pounds????"
Ron's answer: Not really. The foot pounds of presssure needed will depend on the materials being clamped. The guideline is to apply enough pressure to hold the parts in proper alignment and you have a little bit of epoxy being squeezed out of the joint. Just a little.
Michael asked about the color of the mixture. This depends on the brand and type of epoxy being used. Some are yellow-ish, and some are clear.
http://jimmyskiff.blogspot.com/2007_01_01_archive.html
In Response to: Re: epoxy concerns by larry brown on Mar 1, 2008
