Re: help with wood duck p
Posted by MrKim on Dec 24, 2007
I carefully measured and measured...Then noticed small holes drilled in the deck, which correspond to holes in the hatch spacer. Wire the spacer to the deck. Make sure the holes line up. It goes one way.
A tip that should be in the manual. I heard a better manual is on the way.
In Response to: Re: help with wood duck p by chris on Dec 24, 2007
