Re: sass-14->15
Posted by Robert Hancock on Nov 22, 2007
Theo, I weigh 95K which is about 210LB ,the canoe itself weighs 13k, 28lb, I like to build as light as I can , and often carry a homemade cart ,water thermos flask and lunch boxes etc.approx 5k or so.The lapstitch method of construction makes a very strong boat using 4mm plywood.If the water is not rough enough to swamp the boat then the Sassafras will handle it. Robert
In Response to: Re: sass-14->15 by theo on Nov 21, 2007
- Re: sass-14->15 by Bruce Knapp on Nov 22, 2007
- Re: sass-14->15 by theo on Nov 22, 2007
Re: sass-14->15 by Robert Hancock on Nov 23, 2007
- Re: sass-14->15 by theo on Nov 23, 2007
