Re: Lumpy fillets
Posted by Laszlo on Nov 16, 2007
Mark,
You can avoid the pressure on the fillets that makes them bumpy by wetting out the tape before putting it in the boat. Do this on a plastic-covered surface and use a squeegee to remove the excess epoxy. Then roll it up, put it at one end of the fillet, unroll it and smooth it into place with a gloved hand.
Doing this in combination with letting the fillet cure up a bit first as George & Chris recommend will give a perfectly wet-out, light and smooth joint.
In Response to: Lumpy fillets by Mark on Nov 16, 2007
- Re: Lumpy fillets by Mark on Nov 16, 2007
Re: Lumpy fillets by Jim L on Nov 17, 2007
- Re: Lumpy fillets by Mark on Nov 17, 2007
- Re: Lumpy fillets by Lee G on Nov 18, 2007
