:what to paint?
Posted by theo on Nov 3, 2007
I prefer to paint the outside of the hull to define the lines of the boat because plywood often has grain lines going in wild directions; that distracts the eye from the shape. The deck and cockpit, better to varnish, if you paint the deck white you'll be blinded by the brightness on a sunny day, and you can't see the lines of your own boat when you're in the cockpit anyway. Yes, I've had my boats out before the finish coat is on.
In Response to: Re: When to Paint? by Laszlo on Nov 3, 2007
