Re: MAS and System3
Posted by craig on Aug 17, 2007
System three silver tip labels say that you can mix it with thickeners, but it will work better if you use their specially formulated method. I have not found any weakness of using thickners in the regular stuff. This might mean something if you were using it for bridges or power boats, but I haven't seen any local power boat builders even switch to epoxy yet, much less an epoxy as expensive as Silver Tip
In Response to: Re: MAS and System3 by CLC on Aug 16, 2007
