Re: Curvature of aft hatc
Posted by Ed, NY on May 22, 2007
I do not see anything to loose by trying to introduce a slight additional bend per CLC's recomendation. Warmed epoxy does allow movement if done carefully. I was able to bend a hatch made by laminating two layers of ply several days later by heating with a hair dryer and then clamping them to frames cut to the corrected radius.
On the other hand you could just varnish over that 1st hatch cover and hang it on the wall for decoration. It sure is pretty.
In Response to: Re: Curvature of aft hatc by Kim on May 22, 2007
