Re: Panel layout
Posted by Chris J. on Mar 28, 2007
Jeremy...go with the fair curve. I've built 2 CH16's and am finishing up a Mill Creek 16.5, all built from plans. On all the projects I also had to slightly deviate from some of the carefully measured lofted points to obtain a fair curve with my batten. All the boats have stitched together perfectly. Cut a bit outside the line and spend the extra time cleaning up the cut with a block plane. It's worth the extra effort.
Good luck
Chris
In Response to: Panel layout by Jeremy on Mar 28, 2007
