Re: Gaps in Stitching
Posted by CLC on Mar 22, 2007
?>>>>Might it be a good idea to reinforce these two seams with 'glass tape prior to final stitching/compression and the epoxy process?>>>>
Nay---if that scarf was going to let go it would have done so by now. I think you're fine and the hull will get tons stiffer as you add fillets and fiberglass.
In Response to: Re: Gaps in Stitching by Norm on Mar 22, 2007
