if you are getting blobs
Posted by Charlie Jones on Mar 12, 2007
you are putting the epoxy on WAY too thickly. You should be putting on fairly thin coats, using preferably a squeegee.
Then use a scraper to get rid of any little bumps.
And yes- you can patch in some glass and feather the edges- you'll more than likely see the edge, but few others will ever notice, particularly on the bottom.
In Response to: Fiberglassing Woops by Mike on Mar 11, 2007
- Re: if you are getting bl by Jon T on Mar 12, 2007
