Re: epifanes vs interlux
Posted by Laszlo on Sep 17, 2006
The interlux works fine for me. I saw John Harris use it in his Okoumefest varnishing demo. He made it look easy and it was. I used it in the 65 to 80 degree temperature range, the epoxy was initially sanded to #220 smoothness and I wet-sanded with #400 and #600 paper between coats (#400 first few coats, #600 laste few). It was applied with the CLC foam brushes using exactly the technique in the CLC Shop tips and it came out very smooth & glossy.
In Response to: epifanes vs interlux by Kathrine on Sep 16, 2006
