Re: Epoxy shelf life?
Posted by George K on Sep 6, 2006
So good to see you again! And glad to hear the CH 18 will finally be in the water. As said before, the epoxy is fine. If you have MAS the hardener will be really dark by now and may take a few extra hours to fully cure. I have some about the same age as yours, kept in the same conditions and I found it does take a bit longer but it's still good. Be sure to post some pix when you actually do get it wet!
George K
In Response to: Epoxy shelf life? by Monterey Matt on Sep 5, 2006
