Paint Solved
Posted by Peter on Aug 24, 2006
Thanks for all the suggestions, I put the last coat on this morning and it dried as well as I had hoped. As it turned out I had put the problematic coats on too late in the afternoon. As the sun set and the temp cooled the hot air trapped in the boat condensed, and well you know the results.I imagine part of the problem could also be attributed to paint just about past it's shelf life. This was the last of it anyway, so at least it wasn't wasted. Thanks again.
