Re: Weird wood physics...
Posted by JB on Aug 10, 2006
Thanks to both of you! I think you're right. the panel was lying on the driveway and the sheer clamp was on top. The sun caused the sheer clamp to lengthen while the ply stayed in place -causing it to hook down. Putting it back in the garage overnight let both pieces stabilize. But I may try your moisture trick if it doesn't return fully.
I was freaked for a while that's for sure. Cool boat though. Fun to build.
Again, thanks!
In Response to: Re: Weird wood physics... by CLC on Aug 9, 2006
