Re: Stirring Varnish?
Posted by Mac on Apr 18, 2006
My experience with Epifanes and Z Spar Flagship varnishes indicate that a good 24 hrs is needed before wet sanding in preparation for the next coat. The heat lamps will hejp. Once your last coat is on, you'll need several days - up to 2 weeks - before the varnish actually reaches maximum hardness. Many experienced folk on this forum sun cure their boats to speed up this process. I learned the hard way that you can mar your finish with ropes and straps even after 3 days of "curing".
Go slow if and wherever possible, is now my catch phrase.
This is the part of your project that EVERYONE sees - novice and expert alike.
Cheers,
Mac
In Response to: Re: Stirring Varnish? by Darryl on Apr 18, 2006
- Re: Stirring Varnish? by M Davis on Apr 18, 2006
Re: Stirring Varnish? by Mac on Apr 18, 2006
- Re: Stirring Varnish? by Peter on Apr 18, 2006
- Re: Stirring Varnish? by John F on Apr 18, 2006
- Re: Stirring Varnish? by Mac on Apr 18, 2006
- Re: Stirring Varnish? by John F on Apr 20, 2006
- Re: Stirring Varnish? by Doug on Apr 18, 2006
