Re: Bulkheads
Posted by tim on Mar 3, 2006
Thanks for the reply. Sorry for the late acknowledgment, just got back from dogsledding adventure in western WI. I plan to trim the bulkeads at the base where they meet the hull panels to fit at locations spec'd in the WR18 manual.
I did have a question also I forgot to ask, simply out of curiosity, more-less. The max beam will eventually be controlled by the placement and size of the bulkheads. If I trim them this will affect this dimension slightly, not overly critical?
Also, is the max beam technicaly measured from the outside of the hull or the inside? This is a topic of debate here.
In Response to: Re: Bulkheads by CLC on Feb 24, 2006
