Re: Waves after epoxy
Posted by Howard on Jan 14, 2006
if you have not yet sanded the boat, what would be normal is to see some of the glass pattern coming through the epoxy. you will also sometimes get some slight waves where the glass pulled a bit in a non-uniform fashion.
once you sand the boat...and then re-epoxy, it should be smooth with no orange peel or waves.
In Response to: Waves after epoxy by Chris J. on Jan 14, 2006
