Re: out of cab-o-sil
Posted by bubbacrawfish on Jan 12, 2006
Trent, I think you will be alright with just wood flour. it will be dark though and thougher to sand. You can use colloidal silica. All cabosil does; is it thickens the epoxy and it makes it easy to work with. Colloidal silica does the same thing.If the stuff is cheap go for it. Good Luck.;a;1;ID;,Epoxy...Adhesives,WEST.System.Epoxy,WEST.System.Fillers,WEST.System.406.Coloidal.Silica
In Response to: out of cab-o-sil by Trent on Jan 12, 2006
