Re: filling chines and ke
Posted by George K on Nov 22, 2005
Chris,
Fill 'em now. I just use wood flour for the mix as the end grain of the plywood is on the dark side. Some guys will add a bit of cabosil to lighten the color a bit. All in what you like. Both will make for a goodlooking bright finish. I mask off all the seams before I fill as it saves a bit of sanding and will keep any discoloration from the mix getting on the panels.
George K
In Response to: filling chines and keel by Chris on Nov 22, 2005
- Re: filling chines and ke by Mark Camp on Nov 22, 2005
Re: filling chines and ke by Howard on Nov 22, 2005
- Howard's right by Mark Camp on Nov 23, 2005
- Re: Howard's right by Kevin Johnson on Nov 25, 2005
- Re: Howard's right by Chris on Nov 25, 2005
- Re: Howard's right by Kevin Johnson on Nov 26, 2005
