Re: Varnishing
Posted by James Eager on Nov 8, 2005
Gotta go with Steve on this. I use the yellow foam rollers and added a little penetrol. I cut the rollers to fit on a trim sized roller frame just to save ...because they get chucked after each coat. Roll fast and thin and then nock the bubbles out with the tip of a foam brush. You can coat your hull very little time so why try to lay it on heavy? You gotta wet sand between coats anyway so dont make more work for yourself. The results will look as good as sprayed with out the fancy equipment.
In Response to: Re: Varnishing by RogerJ on Nov 8, 2005
