Re: removing green paint
Posted by Howard on Oct 21, 2005
you can wet sand with 400 grit sandpaper. it will take it off with only a minor scuff to the varnish which you can then touch up.
a grey scotch brite pad would also likely do the job.
In Response to: removing green paint from by Jon T on Oct 21, 2005
