Re: Kayak wear protection
Posted by Gober on Oct 18, 2005
Would you be applying this directly to the wood or on top of your epoxy? If you are applying on top of epoxy; to remove it you may only have to heat it with a heat gun. This would soften the epoxy and enable you to get a putty knife under it. Just my thoughts.
In Response to: Re: Kayak wear protection by terry on Oct 18, 2005
