Re: Keep epoxy off shears
Posted by terry on Sep 27, 2005
Good advice on using the rasp to remove any cured epoxy prior to planing the sheers. Actually, I start the sheer planing with a little Surform plane, using this to knock off the drips, as well as doing the ititial cutting of the glass-covered side panels. Doing this eliminates most of the nicks your carefully sharpened plane iron would otherwise get while planing the clamps.
And that's the plane truth
terry
In Response to: Re: Keep epoxy off shears by Doug Judd on Sep 27, 2005
- Thanks all, EOM. by Mulepilot on Sep 27, 2005
