glue joint,,
Posted by LeeG on Sep 26, 2005
if it popped off then it wasn't bonded well to begin with. If you applied wet goop to dry wood it should be attached with a bond stronger than the wood. The big gap really has nothing to do with it as long as there's a fillet conneting things.
In Response to: Bulkhead joint split... by FrankP on Sep 22, 2005
